Hello...
I’ve created a MSI install for Revit 9.1, this works fine however when I run the program after installation it’s asking for the help content.
The dialog that appears allows you to load the source cab file by either:
1. Inserting the CD, this is no good for me because then we have to visit each PC, additionally it hard codes the CD Driver letter which could make it fail as well.
2. Having the CAB File present in the same folder as RevitInstall.exe. RevitInstall.exe isn’t present on the PC, I guess it’s probably installed when you use the CD to install instead of the msi.
I’ve tried extracting the files in manually but that hasn’t worked, how do we get around this problem?
Cheers
Andrew
