I encounter many problems with revit architecture 2015 on windows 8.1 (pro)
for example i can't use the "open" command because this action freezes revit.
At the start, i can create a new project but in the project explorer i can't create a new sheet for the same reasons (no dialogbox and freeze of revit)
My graphic card is Autodesk certified on this product (Nvidia quadro K1100M + nvidia driver 334.95)
Help!!
Someone have an idea (autodesk hotfix, laptop configuration )
Olivier
Have you spoken to an Autodesk Tech? or your Autodesk Reseller?
LD
If you have invalid mapped drives or your Windows profile is on a server instead of local, this kind of thing can happen. Please verify your settings.
thanks for your anwer.
I found the problem.
In my configuration (nvidia quadro K1100m card + resolution 3200x1800 (recommended), if i use a very high (200% default) height for all element on the desktop the blinking mode of revit 2015 is enabled 🙂
The max height for me is high (150%) --> see attached file
