Hello
I have some problems with linking rcp/rcs files in Revit 2015.
First thing i do is to import the Raw files in ReCap, in this project they used *.e57, it was 7 of them and a total of 20,3 gb.
Everything shows up fine in ReCap, i now clip out all the trash outside the building. And saves the project, i get now one *.rcp file and 163 *.rcs files.
Then starting a new revit project, and setting the Project Base Point of a known point in ReCap. And then i start linking my project, origin to origin.
I can know hoover over the linked file, because its near my PBP. But i cannot se the Point Clouds. Its invisible.
Can anyone give me some tips to make this work? i use the latest 20140606_1530(x64)
Update Release 3.
Running into the same problem.
Is there any workaround available to avoid this issue?
When do you expect Update Release 4 becomes available?
We can't say when UR4 for 2015 will be released, however when it becomes available it will appear on our Revit downloads page and usually Resellers will also announce that it is available and usually they will also have a link to our downloads page. I recommend checking the site periodically.
Revit Downloads:
http://knowledge.autodesk.com/support/revit-products/downloads#?sort=score
Hi all,
I had the same problem. In ReCap I created a new project from e57 files and the point cloud looks fine. After inserting the point cloud into Revit it was invisible.
I tried to insert the same point cloud into Revit 2014 and it it works. You could also open the Revit 2014 file in Revit 2015 and the point cloud was visible.
Maybe this helps as a workaround!
Jörg
2 years on has this been sorted yet?
We are restricted to using revit 2015 for various reasons, and are unable to use point clouds from recap?
