Hi everybody..
I got so excited to upgrade my Revit 2014 to Revit 2015...Installed the content libraries...Finished Installing...I hoped I would get the architecture,structure and mechanical template as the previous 2014...It wasnt there..
If there is something that went wrong with the installation..please share...I have been doing this right I have no idea why this went wrong
Solved by LisaDrago. Go to Solution.
Same here!, I had to copy my 2014 libraries to the RVT 2015 file in order to recover these options, also the MEP families were not to be loaded as in Revit 2014, I highly recommend you to copy those files from 2014 as well. I have the students version, as a student I don't fully depend on Revit to survive, but I don't get why Autodesk is not offering any solutions to these absences, because for a real office this can mean trouble.
BTW, copying the 2014 families means to have to run the automatic update Revit does with older families, I know this is a once in a lifetime thing, but is annoying as you have to open every single family and template so 2015 Revit can use'em. ANNOYING....
Hello @Anonymous - you are able to specify what templates show up in that are under your Options>FIle Locations, I have attached an image for reference.
You can place your company template here for quick access.
LD
from the help see if this works
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-851D6C9F-3E00-460D-B49E-341C22D3B9B5
DarrenP
Hi I used the method you guys mentioned but I cant seem to find the template files. I've attached a screenshot that shows that my Metric Library is empty. It is the same with US Metric and US Imperial. There are just no template files. I've even tried editing content libraries and it shows that US Metric, US Imperial and UK have been installed :S Dunno if this matters but I had revit 2015 previously installed on my laptop and this problem only occured after I uninstalled and re-downloaded the programme. I've been trying to figure this out for ages but I have gotten no where! Any help would be much appreciated!
shivani
