Hi there,
I'm trying to install Revit 2014 (a student copy) on my laptop. Since the laptop has a older Core 2 Duo cpu, the device is not able to run a 64 bit OS.
This is why I'm running Windows 8.1 Pro 32 bit. I downloaded the installer from the Autodesk website, it's a 32/64 bit installer (Autodesk_Revit_2014_English_Win_32-64bit_dlm).
After extracting the file I try to run the setup. But i get the following errer:
"You cannot install this product on the current operating system."
I searched the forum and most people say that the installer is probably 64 bit and the OS 32 bit, or visa versa. But in my case the installation file clearly says it's 32-64 bit. So it should be compatible whit my OS no mather what.
Some other people suggested i should install .NET framework 3.5, i did but still no succes with installing Revit.
And some other people suggested i should modify the setup.ini file and remove the 'checkOSversion' line from it. I did, and yes Revit did finally install itself on the laptop. But after installation i wasn't able to run the program, it force clossed itself after 1 second.
As you can see i tried many things but nothing worked out for me. Do you guys have any suggestions?
Thanks, Christiaan
Technically, we have not certified Revit 2014 on Windows 8.1. I would try to run the setup.exe in compatibility mode. It similar to step 4 here:
http://upandready.typepad.com/up_and_ready/2013/07/unsupported-autocad-2014-on-windows-vista.html
You may need to do this as well.
Do you have a certified or tested card?
I have noticed that each year that the software is released, it requires a bit more power in terms of CPU and Video. It is possible that your current configuration may work with a 2013 product and will not work with a 2014 product.
You may try this if the Geforce card can do it....
I have been informed by the QA team that Revit 2014 only is supported on Windows 8 in 64 bit mode only.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15385625&linkID=21208795
Hi there,
i have the solution for your problem
if u didnt get solution yet
contact me : kadri.wael@gmail.com
Hello, I wanted to ask you how did you modify the Boot.ini file from your operating system window in August
Hi Kadri,
I am also trying to installe Revit in my Windows 8 system and does not install. Do you any leads?
My firewall is off, I have tried Revit 2014, 2015 student version and free trial version.
Thank you,
Camila
hey every body ,
sorry for answering just now !! i got some probs .
the solution is simple , you explor the CD and you right click on the setup file then you go to proprieties - compatibilty then you follow the instructions on the picture and that will be OK .
anyway thats how ive done to install revit 14 on my 32 system
hope that will be good for you .
Hey there, have the same problem. Would appreciate your assistance.
How did you get around it?
Thanks 🙂
I just reinstalled my 2014 Revit LT from an older computer to a new computer running Windows 8.1 and it keeps crashing. I just saw from this post that there were compatability problems - but that post was old. Has the issue been resolved?
buenas tardesm estuve correot Sobre la instalacion de Revit en 8.1 de Windows de 32 bits
presento El Mismo Problema, Poseo ventanas portátiles UNA 8 y por tanto el de 32 bits. sonda tambien El que instaler indica Ser párrafo 32 bits y 64, Pero No me Funciona.
Que solucion dados Usted Que Tiene?
favorecer la respuesta al correo maria_quintino93@hotmail.com
