Revit 2014 - linking elevation name to room name
1 REPLY 1
mvitale81
536 Views, 1 Reply
I am curious to know if it is possible to link an elevation name to a room name. Example: Instead of the auto name "Elevation 1-a" it would name the elevation according to the room that is is associated with. I've done a little research on it, but this is the closest thing I have found to a solution.
http://thebuildingcoder.typepad.com/blog/2013/03/rename-view-by-matching-elevation-tag-with-room.htm...
I don't know much about coding and was hoping there would be a plugin that somebody knew about that could achieve this solution. Hopefully this is something autodesk can incorporate into the next version!
1 REPLY 1
jeremytammik
in reply to: mvitale81
Dear Mike,
Thank you for your query.
I am not aware of any such add-in ready-made.
You could take the source code provided by The Building Coder and adapt that to your needs, or ask someone more knowledgeable in Revit add-in or macro programming to do it for you.
That's what it is there for 🙂
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
