Revit 2014 Material browser now working
6 REPLIES 6
rxgao
942 Views, 6 Replies
I've downloaded Revir 2014 recently, and the material and material editor are still not working; nothing comes out when i click the icon (Manage > materials), or Type Props>Edit Assembly>Material... i have no idea why this is happening, and I've uninstalled all other Autodesk software to avoid conflict and have deleted material library 2012 which came with AutoCad2012 but the problem is still not solved... any advice please? thanks .
6 REPLIES 6
barlabro14
in reply to: rxgao
hi i have the same problem too my material and material editor is not functioning how did u solve yours? i also installed revit 2014. but it happened to 4PCs that revit was installed we cannot use material and also worksharing is not functioning it always ends up that 1local file will be disconnected to the central file if other local file collaborates to the central file
ennujozlagam
in reply to: barlabro14
have you installed all the latest updates?
barlabro14
in reply to: rxgao
wat latest updates shall i install? im sorry im not really familiar to apps i should install, when i checked control panel the autodesk material library is installed but the icon is just blank is it really installed?
ennujozlagam
check this websites for updates.
http://knowledge.autodesk.com/support/revit-products/downloads#?sort=score
or
read this thread.
http://www.revitforum.org/architecture-general-revit-questions/19786-material-browser-icons-not-work...
hope it helps.
barlabro14
in reply to: rxgao
ok ill check for it thaks for the link, anyway could you pls give me some videos in doing ellipse staircase?
ennujozlagam
here is the link :
http://designreform.net/learning/2012/05/14/revit-2013-component-based-stairs
