I have just downloaded Revit 2014 and I can change my project units to metric from imperial but all my families are still in imperial, I was wondering how to change those to Metric too. thank you for your time
Solved by Tony_Michniewicz. Go to Solution.
Solved by LisaDrago. Go to Solution.
I tried everything you have said multiple times but it simply does not work..pls its really frustrating so can we pls have a downloadable?
For those of you that are experiencing problems with the installation of Revit content, I would recommend the following:
The key is to remove all content before attempting to reinstall it. This is necessary because you are currently in a state where Revit is incorrectly under the impression that content installed properly. Steps 1 through 5 get you back to a state where Revit is aware that no content is installed and subsequent attempts to add content should be successful.
It is also VERY important to note that you must have an active internet connection when running through these steps because some Revit content may need to be downloaded during this process. I also recommend disabling any anti-virus software during this process to ensure that it does not block the download of Revit content.
Another recommendation is to add autodesk.com to the list of trusted sites in your Internet Explorer options. This can be accomplished through the following steps:
Finally, changes were made in the Revit 2015 installation and now Revit (the program) is installed separately from Revit content. For 2015 users, you need to launch the maintenance process for Autodesk Revit Content Libraries 2015 and not Autodesk Revit 2015.
Tony Michniewicz
Autodesk Revit QA
to all experts i tried all this bt last when i floowed ur steps see wt i get i get just few door types plz help me i luv those autodesk products... plz help me wt to do i am confused...
Unfortunately, it is not clear why you are only getting a portion of the content installed. Beyond retrying the steps I've outlined previously, my next suggestions would be:
Tony Michniewicz
Autodesk Revit QA
thanks bt i think i will download revit 2013 now n hope it will fix the problem
i installed revit 2014 its working.
the problem is adding "Door, Window ..column..etc... its shows "No Door Family is loaded. Would you like to load now" If i made Yes. No files to be there!
Now wat can i do. To load the library files?
Please give solution.
@Anonymous wrote:Can you give me metric families such as doors,windows,walls and interiors? And tell me how to install it.
-Architect Rais
you are right thank you. but in metric libbrary there is nothing i mean empty. and what shoud i do for fulling the libbrary as imerial libbrary? kindly tell me the procedure
What version of Revit are you using? If it's 2015, you may not get the "Add or Remove Features" option when you right click on "Autodesk Revit" in the Uninstall or change a program window. Instead, try right-clicking on "Autodesk Revit Content Libraries". Here you should have a box that says, "Add or Remove Features" Once there, a window should open where you have the option of choosing US Imperial or US Metric.
