Revit Architecture
New Member
Marlum
Message 1 of 20 (19,447 Views)
Revit 2014 Imperial families
19447 Views, 19 Replies
07-25-2013 01:20 PM
I have just downloaded Revit 2014 and I can change my project units to metric from imperial but all my families are still in imperial, I was wondering how to change those to Metric too. thank you for your time
LisaDrago
Message 2 of 20 (19,402 Views)
Re: Revit 2014 Imperial families
07-29-2013 05:02 AM in reply to: Marlum
Hello and Welcome to the Discussion!
When you go to your libraries - do you see both Imperial and Metric folders? You may have to navigate up one to see both folders. Image Libraries for reference.
If not it may not have been installed.
The best way to do this would be to go to your control panel and then un-install a program
Select Revit 2014 and click un-install/Change (don't worry - it won't un-install the program!)
Once the dialog box opens - click on the Add or Remove Features. Image Features for reference.
Then you should be able to see the metric library that can be installed. Image Content for reference.
Make sure it is checked and then Click Next.
This should install the library for you.
Let us know how it goes!
And please come back to the community often and post questions or answers others questions!
Good to have ya!
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
New Member
Marlum
Message 3 of 20 (19,319 Views)
08-03-2013 05:34 AM in reply to: Marlum
you were exactly right, thank you very much, just wondering how to set the metric folder as default? thank you again
Valued Mentor
AJA14
Message 4 of 20 (19,315 Views)
08-03-2013 06:00 AM in reply to: Marlum
Go to application menu, options dialog, File Locations. There you can set up the default templates, family templates, and libraries (Places).
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Member
Winter-s
Message 5 of 20 (19,274 Views)
08-06-2013 04:15 PM in reply to: LisaDrago
Hi Lisa. My revit version is 2012. I did the same thing as you mentioned in above (Add or Remove Features). However it only created a number of empty folders. I wonder any other solution to resolve the problem.
LisaDrago
Message 6 of 20 (19,252 Views)
08-07-2013 04:33 AM in reply to: Winter-s
Hi Winter-S - I did some searching for the 2012 content and it took me to this page >HERE<
Basically starting in the 2012 version it tells you to do what I have said above in this post.
I looked at the wiki help it suggests and it states the same thing...
But there is the 2011 content - you would be able to use that content in 2012 and you are able to download it.
LD
New Member
schulte8
Message 7 of 20 (19,083 Views)
08-20-2013 07:10 PM in reply to: LisaDrago
I have tried to utilize the Imperial families in Revit 2014 and I keep having the attached message pop up..... What is your advice?
I have tried...
-turning off my firewall and reinstalling it
-adding autodesk to my approved sites
-adding the libraries in the add or remove content
I even purchased the software as a student and its very disappointing/frusterating paying money and not having things like these show up..
Please help!
Member
raissss008
Message 8 of 20 (18,934 Views)
09-03-2013 03:55 AM in reply to: Marlum
I am not able to load families in revit 2014,how to do it?
And from where can we download revit 2014 families,any link?
Member
raissss008
Message 9 of 20 (18,929 Views)
09-03-2013 03:57 AM in reply to: LisaDrago
send the link for revit 2014 families and how to install it?
LisaDrago
Message 10 of 20 (18,916 Views)
09-03-2013 05:04 AM in reply to: raissss008
Hello and Thanks for joining the discussion.
If you would refer to the information above - it will give you the information on how to install the library. Also there is no link for the 2014 library. That is also listed above.
LD
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
