Revit Architecture
Member
Message 1 of 6 (3,412 Views)
Accepted Solution
Revit 2013 run very, very slowly on my computer
3412 Views, 5 Replies
07-28-2012 12:02 PM
Hi - Just Instal Building Design Suite Premium and started using Revit 2013 and it seems to run very, very slowly on my computer.
Freeze all windows sistem using 100% for a single Core (windows XP 64bit SP 3, 4GB RAM, Dual Xeon Quad Core 2.33GHz (8 cores), Graphics card  ATI Radeon HD 6790.
It's very disapointing to have to wait that long to any command. The first thing I did after it was installed , was check the graphics driver and settings and drivers are up to date.
Revit 2012 works fine, all other 2013 products work fine, except Revit, in the transistion to 2013. the slowness and random crashing issues we've encountered are frustrating especially since the crashes do not create a recovery file.
Conclusions
Whaiting for an Update in Rv 2013
Then using Revit 2012
The unification of Building, MEP & Structural affect the performance ?
Valued Contributor
Message 2 of 6 (3,403 Views)
Re: Revit 2013 run very, very slowly on my computer
07-28-2012 04:13 PM in reply to: JoseLuisMuñoz5151
XP 64 is not supported by Autodesk.
Get a new computer and watch it fly.
Member
Message 3 of 6 (3,375 Views)
07-30-2012 05:57 AM in reply to: vector3
Tank you for your answer
Well, I think a new computer is not the real answer for the slow down, if you see this links with revit 2013 users with the same problem :
http://www.revitcity.com/forums.php?action=viewthread&thread_id=27351
windows 7 64bit, 12GB RAM, 2.67GHz, NVIDIA Quadro FX 1800 graphics card
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Building-Design-Suite-Ultimate-2013-is-SLO...
Dell Precision T3500 Windows 7 Ultimate 64bit, Intel Xeon 3.20GHz, 12 GB RAM, (2) Nvidia Quadro 2000 1GB RAM each.
 8 core i7 965 processor with 6Gb of DDR3, 12Gb Ram Quadro NVIDIA cards dual GTX280
And in my home I have the same Issues with my notebook
Windoows 7 64 bit . Intel I5 2,4 Ghz 2dn generation 4 gb NVIDA® Geforce GT540M
*Expert Elite*
DarrenP
Message 4 of 6 (3,370 Views)
07-30-2012 06:33 AM in reply to: JoseLuisMuñoz5151
Member
Message 5 of 6 (3,360 Views)
07-30-2012 08:21 AM in reply to: DarrenP
Tanks for the answer and the link,
I try the revit update an tell you.
Member
Message 6 of 6 (3,160 Views)
08-27-2012 02:41 PM in reply to: JoseLuisMuñoz5151
Problem SOLVED
Just install the Update 1 and It Worked
NO Problem with Windows XP 64, or the Workstation configuración
The real problem was install the rigth Update for the suite and not for
Revit standalone versión,
And the Update refuse the instalation but work the 3er
chance. That confuse me but this is for the XP for sure.
And the Update window d'ont show a clear progress bar, just freeze
for severas minutes and sudently appear the Correct instalation window
Thanks for all answers
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
