Bldg Design Suite 2013 was installed correctly and now, Revit loads but doesn't launch. It flashes as if it will start and closes.
HELP!
You might be experiencing a corrupt CascadeInfo.cas file. See http://usa.autodesk.com/getdoc/id=TS13894457 for more information and the fix. The technical solution was written for 2010 products, but I have seen this in later releases. If that is not the problem, you might try searching for crash on startup for Revit in the Knowledge Base.
Check if you have Panda Antivirus Running, there is a patch if this is the case.
Regards
I have had problems with stand alone version in my own compiuters
http://soporte.pandasecurity.com/foro/viewtopic.php?f=37&t=618
Check this out, maybe there is a new version for 2014 products,
Regards
