I am trying to change the dimensions between windows with the 'aligned dimension' but when I click on the dimension it either tries to move the text or asks if I want to change the 'dimension text'
what am I doing wrong?
?? ... select first the window object and then the align dimension will turn in blue showing that now it is editable ..and change it as you want....
Your Name
