Revit 2013 and rotated Photometric Web
8 REPLIES 8
Message 1 of 9
1068 Views, 8 Replies
Hello all,
I am currently testing the Revit 2013 trial and I encountered a strange phenomenon, cf. attached image.
Short explanation: Obviously all light sources of area lights are rotated 90° for rendering purposes. Do I miss something or is this a bug?
Pete
8 REPLIES 8
Message 2 of 9
LisaDrago
What component are you using?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 3 of 9
Hello Lisa,
if you mean with "component" a family, then I can say it's all about "Loadable Families" which was created for testing purposes. And here we are, if it looks correctly in Family Editor then the rendering is wrong. If we do it wrong on purpose in Family Editor (90° rotation like in the rendering) then the result is that the rendering is OK!
I have currently no access to the workstation were trial is installed so I can't give you more screenshots, but I think you can easily control by yourself that there is something going wrong.
Pete
Message 4 of 9
Alfredo_Medina
There are several settings that play a role in this case. What is the current setting of the distribution of the light? Is it linear, or rectangle? Depending on these choices, you see a different set of parameters in the the family types window, including the dimensions of the rectangle, visibility, etc.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 5 of 9
I am not a Revit Expert but I thought that the image shows clearly that I am talking about a "rectangle".
I am wondering if just we have the phenomenon if the following is set in Family Editor:
light source = Rectangle
light distribution = Photometric Web
(correct) Rectangle Width = etc.1200mm
(correct) Rectangle Lenght = etc. 310mm
Emit Shape Visible in Rendering = true
And exactly the "Emit Shape" (a self-luminous surface) is _always_ rendered with a 90° rotation what I suppose to be not correct.
Please confirm that I understood correctly or that this is a Revit bug.
Message 6 of 9
Alfredo_Medina
Can you upload the .rvt file, containing just what is seen in the image?
Message 7 of 9
Hi has there been any resolution to this issue? I have exact same problem and is embarrasing and frustrating expecially when your adjusting exposure levels with the client looking over your shoulder. rotated90.jpg
Message 8 of 9
JM_K
in reply to: joshua.lumley
Joshua,
Did you ever get a resoluton to this issue?
Insert witty comment here.
Message 9 of 9
in reply to: JM_K
2 years later on Revit 2015 and I'm having the exact same problem!!  If the IES is orientated correctly in the family, it Renders 90° off.  If I purposely rotate the the IES web 90° off in the family, it then renders correctly!
Has there STILL been no answer and obviously, a fix????
