Hello Please help solve the printing problem problemu.Voznikla drawings from Revit (Autodesk Building Design Suite Premium) plotter KIP 3100 series. After you select the printer, click properties, and an error (report sent to Autodesk). The same situation arises in almost all programs Autodesk 2013 (AutoCAD 2013 (all), Revit 2013, Design Review,). Normally only prints of Design Review 2013.
Drivers take away: http://www.kip.com/appdetails.asp?id=PC% 20Based
Operating system: Windows 7 x64.
Do you know if you are using KIPGL or KIPScript when plotting? This setting is under the Printing Preferences for the plotter. We have to use KIPScript or Revit crashed.
See attached.
