Revit Architecture
Active Contributor
Message 1 of 10 (927 Views)
Revit 2013 and Citrix
927 Views, 9 Replies
11-12-2012 02:35 PM
Revit 2012 and Citrix Xenapp work great. We upgraded to 2013 and now everything as slowed down so much it is basically not useable. Has anyone else delt with this issue? Is it a by product of Revit 2013, are their some graphic issues present in this release currently not in 2012? Anyone else experiencing this issue?
Message 2 of 10 (846 Views)
Re: Revit 2013 and Citrix
12-26-2012 01:57 PM in reply to: jimk
Dear jimk
The issue you are describing has been reported to development group and is currently under investigation.
Best regards
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
New Member
Message 3 of 10 (740 Views)
01-28-2013 07:32 AM in reply to: john.lipp
Any new info on this issue?
Active Contributor
Message 4 of 10 (690 Views)
02-05-2013 07:07 AM in reply to: mlestes1
I wish there was. The problem is still a glaring issue with no solution. I am fairly certain there won't be. I am hopeful that 2014 will run better, but we could be faced with the same problem in that release as well. We are looking at trying to accelerate the data with Cisco WAAS as it will work with citrix. Hopefully can get equipment in place in a few weeks and test. 2012 still runs excellent, and we try to keep as many projects in that version as we can.
Member
Message 5 of 10 (528 Views)
04-11-2013 02:43 PM in reply to: jimk
I'm seeing similar problems.  Was there ever an update on it?
Active Contributor
Message 6 of 10 (525 Views)
04-11-2013 03:01 PM in reply to: stip1
No I never received a solution for this. I am hoping 2014 is better, I see the did some video stuff in that release. What is so disappointing is 2012 works and runs like a champ.
Active Contributor
Message 7 of 10 (433 Views)
05-07-2013 08:37 AM in reply to: john.lipp
2014 is showing the same behavior as 2013. How could this not be addressed, is there anything we can do? Why say it works on Citrix when you can't hardly run it on Xenapp
Member
M.Abrahams
Message 8 of 10 (391 Views)
05-12-2013 10:24 PM in reply to: jimk
Attn: Autodesk Urgent!
This is a serious issue that could have major ramifications to the operations of some companies. 2012 had been working fine on XenApp but 2013 was just far too slow. My understanding from the documents I had read from Autodesk, was that Revit was supported for citrix for 2014 but by the sounds of it, that isn't the case. We are about to test it ourselves but this could have a serious impact on our systems and projects.
Having this fixed for 2014 would be great but we will still have a large number of projects in 2013 that would be affected if/when crossed over to XenApp so a fix for 2013 would also be needed.
Please give us some form of indication whether this will be addressed and addressed soon.
Cheers
New Member
Message 9 of 10 (148 Views)
01-08-2014 02:35 PM in reply to: jimk
This question is for Autodesk: are Revit 2013 and Revit 2014 ready or not ready to perform appropriately as virtualized applications on Citrix Xenapp? Our firm has invested quite some money on a Citrix server farm used mainly for other applications than Revit and we would like to leverage the benefits of this new approach on large BIM projects.
Did any of the other guys get any answer on this matter?
Best wishes for 2014!
Albim14
Active Contributor
Message 10 of 10 (128 Views)
01-09-2014 06:36 AM in reply to: jimk
We ended up getting a cisco server that supports the Nvidia K2 grid card. All Autodesk apps work excellent on there and are very happy with the results. The key to making it run smooth was the grid card.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
