Revit Architecture
Valued Contributor
kwihae
Message 1 of 4 (386 Views)
Revit 2013 Stairs by Compoenent depth clipping in plan
386 Views, 3 Replies
12-17-2012 06:27 AM
I have a fire escape stairs running from the basement to the 4th floor on the exterior of the building.  This is built as one element.
Does anyone know if there is a way to clip the view of this stair so that only a portion of the stair is showing?
For example, I would only like to clip out the stairs in the basement in the 4th floor plan.
ccollins
Message 2 of 4 (377 Views)
Re: Revit 2013 Stairs by Compoenent depth clipping in plan
12-17-2012 08:38 AM in reply to: kwihae
You could try using a Plan Region, and set the View Range specifically for your pruposes at the fire escape.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Valued Contributor
kwihae
Message 3 of 4 (369 Views)
12-17-2012 09:56 AM in reply to: ccollins
Tried it, but didn't work...
ccollins
Message 4 of 4 (356 Views)
12-17-2012 12:27 PM in reply to: kwihae
Can you post an image or a stripped down version of the revit file?
Cliff B. Collins
St. Louis, MO
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
