Revit 2013, NO templates or libraries??
6 REPLIES 6
fadi.naccache
10517 Views, 6 Replies
I just started working with revit 2013 but i cant find any templates or libraries. Never used revit before so i dont have any old ones to copy. What to do??
Tnx
6 REPLIES 6
in reply to: fadi.naccache
First confirm that those folders are not really there. Go to C drive>ProgramData>Autodesk>RVT 2013
you can download it from web and paste them at specified path.
(OR if feasible, you can copy it from any other machine from your friend or office)
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Yes, It is confirmed that there is no corresponding folder for libraries or templates.
I tried to find some on the web but couldnt find anything serious, do u know any good one?
loboarch
It sounds like the content did not get installed.  You can repair the install and make sure "install content" is checked in the installer process.  This will get all of the content install as needed.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Thanks for trying to help. I got it to work and i write this because alot of ppl has had this particulor problem. I think it became a conflict in my computer due to the fact that i already had autocad 2012 installed on the computer. I tried all kinds of diffrent strategies to solve the problem on my computor but it didnt work. Finally i installed the program on a diffrent computer which did not have any autodesk program preinstalled and it worked fine. I just copied them over to my computer and it works nice. So if u get this problem try this strategy and it might work.
