I just installed the student version of Revit 2013. I opened it and everything seems to be working expect when I draw anything (ie topo surface, wall, etc.), the modify tab is missing all the draw options (line, circle, etc) as well as the Finish and Cancel buttons. This makes it impossible for me to use the software without those. Is there a way they could be hidden or is the software just corrupt?
Please let me know.
You need to install the update #2 to Revit 2013 to correct this behavior. It is due to a compatibility issue between .NET 4.5 and Revit 2013. I am guessing you are trying to run this on Windows 8 which needs .NET 4.5 to run. revit 2013 needs to be updated to avoid this conflict.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679039&linkID=16831210
I am facing the same issue with the student version. I installed UP1, UP2, UP3. I now see start and finish check marks but I don't see draw panel.
Plese help!
Make certain that you have Update Release 2 for your version of Revit 2012 installed, and then apply the .Net 4.5 hotfix. Links to the Update Releases and the Hotfix can be found in this blog article.
