Revit Architecture
New Member
Message 1 of 4 (2,035 Views)
Revit 2013 Modify Tab Missing Finish and Cancel Options
2035 Views, 3 Replies
02-10-2013 10:28 AM
I just installed the student version of Revit 2013. I opened it and everything seems to be working expect when I draw anything (ie topo surface, wall, etc.), the modify tab is missing all the draw options (line, circle, etc) as well as the Finish and Cancel buttons. This makes it impossible for me to use the software without those. Is there a way they could be hidden or is the software just corrupt?
Please let me know.
Employee
loboarch
Message 2 of 4 (2,004 Views)
Re: Revit 2013 Modify Tab Missing Finish and Cancel Options
02-11-2013 12:55 PM in reply to: Gabmariestef
You need to install the update #2 to Revit 2013 to correct this behavior.  It is due to a compatibility issue between .NET 4.5 and Revit 2013.  I am guessing you are trying to run this on Windows 8 which needs .NET 4.5 to run.  revit 2013 needs to be updated to avoid this conflict.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679039&linkID=16831210
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Member
Message 3 of 4 (566 Views)
01-30-2014 11:22 AM in reply to: loboarch
Is this compatibility fix also the case with it not working on a Windows 7 professional OS?
*Expert Elite*
Message 4 of 4 (542 Views)
01-31-2014 03:21 PM in reply to: chelleOnO
If .NET Framework 4.5 has been installed on your computer running Windows 7, you will experience the same issue, and need the same fix (hotfix for 2012 versions; latest Update for 2013 versions).
David Koch
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
