Hi, is there any way I can edit the dimension tick size in Revit 2013? Under the type properties there are only two different "tick" options for dimension tick marks: Diagonal 1/8", and Diagonal 3/32". I've looked for the family to edit but cannot seem to find any dimension family. Ideally, we would like to match the text size of 1/24" or 1/32".
Solved by constantin.stroescu. Go to Solution.
Manage > Settings> Aditional Settings > Arrowheads . There you can make the desired changes.
Your Name
Thank you so much. That was awesome, and suprisingly easy. I can't believe I struggled so much with that. haha, anyways, joy to the you, friend!
Cheers!
Cory - HomesByDundee
I know this is an old post, but I was wondering if there was a way to have a arrow head on one end and an architecture tick on the other? for dimensioning. What we are trying to achieve/show is the dimensioning going beyond the window.
Any help would be great thanks
