Revit Architecture
Message 1 of 4 (829 Views)
Revit 2013 Add-Ins Ribbon
829 Views, 3 Replies
12-26-2012 09:30 AM
When you download apps and then add to the ribbon, is there any way to ADD another "Add-Ins" ribbon when number of installed apps exceeds the ribbon's available space ?
Also, some addins create large wide buttons ie: IFC Exporter for Revit 2013 and Revit IFC Export Alternate UI 2013 which have no purpose other than to tell you they are installed. How would you delete these buttons from the Ribbon, as they really have no purpose.
Thanks for any help.
Message 2 of 4 (806 Views)
Re: Revit 2013 Add-Ins Ribbon
12-27-2012 03:57 AM in reply to: Lineabove
it is possible to do throgh additional programming.
a programmer can add more tabs.
Message 3 of 4 (796 Views)
12-27-2012 05:44 AM in reply to: Intecinfocom
I was hoping that this would be something that could be accomplished through the CUI or even by modifying the *.addin file.  Will wait and see what the 2014 version brings.
Message 4 of 4 (787 Views)
12-27-2012 07:28 AM in reply to: Lineabove
may be some other users can suggest a better alternate.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
