Revit 2012 - complex roof
5 REPLIES 5
N0178294
745 Views, 5 Replies
Could anyone help me with trying to create a curved roof? I want it to be flat apart from where the sloped walls are, the sloped walls are in-place models.
I thought I could do it using swept blend but i'm a little unsure of how to approach it.
I must warn you I'm a bit of a rookie with Revit.
Any help is appreciated.
5 REPLIES 5
ccollins
in reply to: N0178294
Create a flat roof by footprint method.
Then, along the sloping walls, use "edit points" to conform the roof to the wall profile.
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
N0178294
When i try to edit the points it wont let me change them vertically?
ccollins
You should be able to click the points, and then type in a new value, in reference to your Level.
Cliff B. Collins
St. Louis, MO
N0178294
sorted it, thanks for your help Smiley Happy
ccollins
Glad it is working.
Please check "New Solution" for this thread.
cheers
Cliff B. Collins
St. Louis, MO
Rail Community
