I placed a wall below the staircase how to attach the wall to the slating side of the stairs. How to join the stairs to the floor slab so that it reads as a one structure?
Solved by constantin.stroescu. Go to Solution.
Solved by LisaDrago. Go to Solution.
2. In order to make a seamless conection betewen the floor slab and the stair structure:
Welcome to the Discussion!
Another option I would like to throw into the mix - Modify the wall profile.
You will need to do this is a section view of the wall - Select the wall in the section and in the Ribbon you will see the Edit Profile tool - select it. See Image edit profile.
Then you can modify the boundary of the wall to follow the stair. See image - modify.
Then finish the modify and you will see the wall follow the stair or outline you have specified. See image finish.
Both options will work.
LD
Yes, Lisa , you are right - your solution is definitely the most appropriate in case of straight walls.
The workaround proposed by me is more suitable for curved walls or jagged wall succesion , where the Edit Profile for wall can not be applied to. This workaround allows. also to lock the "phantom roof" to the stair underside and thanks to this , moving the stair the wall will keep attached to it..but as any workaround is less handy ....
