Revit Architecture
Member
Winter-s
Message 1 of 4 (334 Views)
Revit 2012 - Wall
334 Views, 3 Replies
08-04-2013 12:03 AM
I placed a wall below the staircase how to attach the wall to the slating side of the stairs. How to join the stairs to the floor slab so that it reads as a one structure?
constantin.stroescu
Message 2 of 4 (267 Views)
Re: Revit 2012 - Wall
08-06-2013 05:47 AM in reply to: Winter-s
  1. To attach the wall o the stair underside:
  • I propose a workaround - make a roof by extrusion as a helper using the underside line of the stair . Make a type of roof dedicated to this..a phantom roof. Attach the wall to this roof and then hide the roof..
2. In order to make a seamless conection betewen the floor slab and the stair structure:
  • make them first of the same material
  • then , the most simple method could be to make a Linework override ( Modify >View > Linework > Invisible Line)
Constantin Stroescu
BIM Manager AGD
LisaDrago
Message 3 of 4 (259 Views)
08-06-2013 06:27 AM in reply to: Winter-s
Welcome to the Discussion!
Another option I would like to throw into the mix - Modify the wall profile.
You will need to do this is a section view of the wall - Select the wall in the section and in the Ribbon you will see the Edit Profile tool - select it. See Image edit profile.
Then you can modify the boundary of the wall to follow the stair. See image - modify.
Then finish the modify and you will see the wall follow the stair or outline you have specified. See image finish.
Both options will work.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
constantin.stroescu
Message 4 of 4 (243 Views)
08-06-2013 06:54 AM in reply to: LisaDrago
Yes, Lisa , you are right -  your solution is definitely the most appropriate in case of straight walls.
The workaround proposed by me is more suitable for  curved walls or jagged wall succesion , where the Edit  Profile for wall can not be applied to. This workaround allows. also to lock the "phantom roof" to the stair underside and thanks to this , moving the stair the wall will keep attached to it..but as any workaround is less handy  ....
Constantin Stroescu
BIM Manager AGD
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
