Revit Architecture
New Member
Message 1 of 2 (484 Views)
Revit 2012 Face based families
484 Views, 1 Replies
06-13-2011 11:20 AM
We have a project that we upgraded from 2011 (that has zero issues) to 2012.  After we start moving around the project we notice that the tags for face based content disapear.
Once you nudge the item they come back.   We've tested it on 3 different systems.
Any ideas?
Employee
ryan.duell
Message 2 of 2 (467 Views)
Re: Revit 2012 Face based families
06-14-2011 05:53 AM in reply to: david.griessmann
It sounds like this could be graphics related; we can do a few quick tests which I have organized below:
1.  First, under Revit 2012 > Options > Graphics, do you have any Warnings similar to “Older Video Card Driver” or similar?  If so I would upgrade the display driver to the latest recommended driver for Revit 2012:
Image Example
2.  Also, in the same Options location, test un-checking Graphics Mode > Use Hardware Acceleration (Direct3D).  Close \ Re-open Revit, and see if the same behavior persists.
3.  If so, in the same location, un-check Semi-transparent.  Close \ Re-open Revit, and see if the same behavior persists.
Image Example all 3 Areas
Thank you,
Ryan Duell
Autodesk, Inc.
Revit Clinic
@revitclinic
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
