The link to the techincal solution link does not work. When you scroll over it is not a clickable link. I have seen this issue throughout other Autodesk pages. Please fix this.
I've updated the thread so that the link should be working now.
This fix only works if you don't have too much content in your RPC folder. I made the fix, but Revit kept hanging as soon as I tried opening a new or existing project. After doing a little digging on the internet, I discovered that if you point ACM to a folder with only a few RCPs than Revit opened as it should.
Does Autodesk have a fix for this yet? Right now I have to point to the folder with fewer RPC to get Revit to launch, but change it to the full folder if I want it all to show up in Max. Its an ok workaround, but certainly not ideal.
I'm only mildly interested in RPC content in Revit, but I really need it in Max. Is there any way to disable the whole RCP search within Revit, so I get the full benefit in Max and can still open my revit without changing paths in ACM?
Unfortunately, there is not a way to disable the whole RPC from running. Right now, the only workaround is changing the folder to one that has less RPCs as you said. I beleive that the number of RPCs that Revit will not hang with is about 300.
The good news is that this is currently planned to be addressed in the next update for Revit 2011 products. I cannot say when the updated is going to be released, and sometimes, things that are planned to be fixed miss the cut, but right now, it is planned to get fixed.
I'm running revit architecture 2011 on parallel desktop 7, Intel quad core GHz, 16GB Ram 750 HDD Ati radon 6570M. i com across the exact same thing, revit just hang there with a spining circle of the curser. I try to open revit.ini but i can not locate the [ACMsetting] . However revit 2011 will run on a 4GB ram, Intel core i3 1.33gHz, 320GB HDD with imbuilt graphics hard. I don't see why it's doing this. System requirements shouldn't be the problem.
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name: AppHangB1
Application Name: Revit.exe
Application Version: 2011.0.2010.903
Application Timestamp: 4c81b6b1
Hang Signature: 6f7f
Hang Type: 256
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Hang Signature 1: 6f7fdbe11f5cbc55870291980279f715
Additional Hang Signature 2: d9f3
Additional Hang Signature 3: d9f3f36fb405da507fbe20ffc3386ffa
Additional Hang Signature 4: 6f7f
Additional Hang Signature 5: 6f7fdbe11f5cbc55870291980279f715
Additional Hang Signature 6: d9f3
Additional Hang Signature 7: d9f3f36fb405da507fbe20ffc3386ffa
