Revit 2011 - 100'-0" Datum Elevation
6 REPLIES 6
davidnowell6822
8014 Views, 6 Replies
In Revit 2011, I'm trying to change the first floor level from 0'-0" to 100'-0" (datum).  I have tried Manage-->Project Location -->Position-->Relocate Project, but nothing happens and there are no error messages.  Thank you in advance.
6 REPLIES 6
doug
in reply to: davidnowell6822
After you have done your listed steps and adjusted your project "up" 100', you need to do one more thing.
Highlight one of the Level lines in an elevation or section view.  In the Properties box, pick Edit Type.  In the Type Properties dialog box, change the Elevation Base parameter from Project to Shared.
Your Level elevations should now show the new elevations.
Douglas Bowers, AIA, LEED AP
Revit Architecture 2016 Certified Professional
Revit Structure 2016 Certified Professional
Revit MEP 2016 Certified Professional
AutoCAD 2016 Certified Professional
www.dougbowersconsulting.com
blog: http://aectechtalk.wordpress.com
Please use Mark Solutions > Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you!
davidnowell6822
in reply to: doug
Worked like a charm.  Thank you Douglas.
doug
No problem.  I'm glad that worked for you.
I'm using Revit 2013, I've done all the same things. But when I select the Level Line, then Edit Type, Type Properties, the only options under Elevation Base are Project Base Point and Survey Point. Is there a different way to change the 0' Elevation Base in Revit 2013?
loboarch
Here is an articel in the wikihelp covering this topic.
http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Modeling/Create_a_Toposurface_Using...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
terry
in reply to: loboarch
The 2013 solution works just great
Rail Community
