Revit Architecture
Member
davidnowell6822
Message 1 of 7 (3,073 Views)
Revit 2011 - 100'-0" Datum Elevation
3073 Views, 6 Replies
04-06-2011 08:27 AM
In Revit 2011, I'm trying to change the first floor level from 0'-0" to 100'-0" (datum).  I have tried Manage-->Project Location -->Position-->Relocate Project, but nothing happens and there are no error messages.  Thank you in advance.
Active Contributor
Message 2 of 7 (3,068 Views)
Re: Revit 2011 - 100'-0" Datum Elevation
04-06-2011 09:23 AM in reply to: davidnowell6822
After you have done your listed steps and adjusted your project "up" 100', you need to do one more thing.
Highlight one of the Level lines in an elevation or section view.  In the Properties box, pick Edit Type.  In the Type Properties dialog box, change the Elevation Base parameter from Project to Shared.
Your Level elevations should now show the new elevations.
Douglas Bowers, AIA, LEED AP
www.dougbowersconsulting.com
blog: http://aectechtalk.wordpress.com
(Previously posting as Doug Bowers through Newsreader for several years)
Member
davidnowell6822
Message 3 of 7 (3,050 Views)
04-06-2011 01:25 PM in reply to: doug
Worked like a charm.  Thank you Douglas.
Active Contributor
Message 4 of 7 (3,047 Views)
04-06-2011 01:28 PM in reply to: davidnowell6822
No problem.  I'm glad that worked for you.
New Member
Message 5 of 7 (2,227 Views)
10-21-2012 04:51 PM in reply to: davidnowell6822
I'm using Revit 2013, I've done all the same things. But when I select the Level Line, then Edit Type, Type Properties, the only options under Elevation Base are Project Base Point and Survey Point. Is there a different way to change the 0' Elevation Base in Revit 2013?
Employee
loboarch
Message 6 of 7 (2,179 Views)
10-22-2012 07:27 AM in reply to: davidnowell6822
Here is an articel in the wikihelp covering this topic.
http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Modeling/Create_a_Toposurface_Using...
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Distinguished Contributor
Message 7 of 7 (1,445 Views)
05-17-2013 12:14 PM in reply to: loboarch
The 2013 solution works just great
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
