Unfortunately I did not have the proper information about Revit...because knowing this could be my decision to implement a new software for my business could be different. But that is not the point, the point is that Autodesk is selling a subscription software, that as soon as you Update your system you need find new consultant or associated, because your currently associates or consultants do not want to update the system or simple they are not able to effort it.
Is complete out of sense that you are getting every year an updated that you can not used..for the reason that mention before...We are working in a system that require that professional office find a proper tools and helper to arrived successfully at the end of each project.
As you mention the reseller did not give the correct information... and let me tell you I know perfectly the AutoCad and something about Revit, and I have used a software and computer for more than 20 years, and I never found a software that new version can not save file in old versions, AutoCad 2010 can save drawing in R12 version, and that make AutoCad a powerful software and you will be able to work with a wide professional offices without ask them what kind of software use for jobs.... An the solution is not go back to AutoCad and forget Revit....I like Revit and in the short time that I have worked with, I have found that could be a powerful tool as AutoCad, but AutoDesk showed us a good product (AutoCad), and taught us to use it, and give us a tool to work with different professional, why not keep doing the same with a Revit... Do not forget that AutoDesk purchased Revit with the intention of fight against Archicad, and now is starting to lose land with decision like update software.
As a Revit users, we need disagree that situation like this, Revit and its update are expensive softwares...does not cost couple of dollars do not forget that.
Edited by: An-Bar on May 19, 2009 10:24 PM
