Revit Architecture
New Member
bruce.sinkey
Message 1 of 4 (3,117 Views)
Revit 09 How do you cut a hole in the generic 12" floor slab
3117 Views, 3 Replies
03-14-2009 09:22 PM
I am just learning Revit and I can not figure out how to cut a hole in a second floor 12" Generic.
I am also having problems seeing my stairs through the second floor.
*cdv
Message 2 of 4 (3,117 Views)
Re: Revit 09 How do you cut a hole in the generic 12" floor slab
03-15-2009 06:16 AM in reply to: bruce.sinkey
Click on the slab to highlight it, click on edit,
then on the design bar click on lines, then look at your options bar and you
will see that you various options in addtion to just drawing lines, choose
whatever you want draw the desired opening in the slab, click finish and Revit
automatically knows that you have cut something out of the slab. So your opening
shouldd be there.
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
I
floor 12" Generic. I am also having problems seeing my stairs through the
second floor.
Distinguished Mentor
Caddman13
Message 3 of 4 (3,117 Views)
03-16-2009 07:27 AM in reply to: bruce.sinkey
> {quote:title=bruce.sinkey wrote:}{quote}
You can cut an Opening in the floor slab by going to the Modeling Tab and toward the bottom Pick Opening and by Face. Drawing a Pink line showing the opening size and finish sketch.
You can also, Select the slab, at the top of the drawing window you should see an EDIT button. Click that and then draw lines for the opening.
When you click on the second floor slab you should be able to see the stairs ghosted under it. You then can trace the stairs to create the opening.
Hope this helps.
Distinguished Contributor
CTREVIZO
Message 4 of 4 (3,117 Views)
03-17-2009 10:44 AM in reply to: bruce.sinkey
simply go to the Modeling Design Tab; click then on the drop down box select the "Shaft Opening" Tool
refer to the "Recent Files" window then click on tutorials or the help link for more knowledge.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
