I am creating a custom title block required for a client. They have special parameters in there revison schedule. Though the revision schedule does not allow to create new parameters. How can I access Revit's Revision Parameter database to add the parameters needed for this revision schedule. Or does anyone have a suggestion on how to make this title block/revisions block to work? Hey Autodesk HINT HINT maybe something for future releases!
Thank you,
By default you cannot add additional parameters to the Revision Schedule View in a Title Block Family;you can only utilize the following parameters:
Revision Number
Revision Description
Revision Date
Revision Sequence
Issued by
Issued to
While you can create additional Calculated Value columns, you cannot add new fields.
Thank you,
