Reveals in columns
3 REPLIES 3
haydenwse
1475 Views, 3 Replies
Reveals in columns
Is it possible to put Reveals in concrete columns?
3 REPLIES 3
LisaDrago
in reply to: haydenwse
The reveal command I believe is specific for walls.
You can edit the family and put a void in...
I guess what exactly are you looking to do?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
haydenwse
I am trying to put a horizontal reveal in a square concrete column.  It needs to be 3/4" wide and 1/2" deep and go around all sides.
LisaDrago
I am thinking the best way would be to customize a column.
It would not take long at all to do. Even if you have all the columns places - you could select al instances (or just the ones you need) and switch them out in the type selector)
LD
