Revit Architecture
Member
Message 1 of 5 (1,158 Views)
Resizing the Viewports
1158 Views, 4 Replies
06-08-2004 06:41 PM
I'm trying to add four views on a A3 sheet, one of the views had to be resized a little but its vewport remain same. Is it possible to resize vewports as well? I know I use to be able to create and add many viewports in ADT, can I add more than one in a single command in Revit?
*Jeffrey McGrew
Message 2 of 5 (1,158 Views)
Re: Resizing the Viewports
06-08-2004 07:24 PM in reply to: TDKD
TDKD wrote: > I'm trying to add four views on a A3 sheet, one of the views had to be resized a little but its vewport remain same. Is it possible to resize vewports as well? I know I use to be able to create and add many viewports in ADT, can I add more than one in a single command in Revit? Yes. When you place a view on a sheet, Revit will assume a default 'viewport' (to use ACAD/ADT terms) border to that view. If you instead open/activate that view, go to view properties and select for it to have a view crop region, then you'll have a user-created border around that view that you can drag around (kinda like an xclip). Then you can select for said border to not be visible in the same view properties, and it won't show up, but continue to properly crop the view. To apply this change to multiple views, create a view template with the desired settings, and then apply that to the views you want to follow those settings. I think you can do this to more than one view at a time to 'batch process' them all to the same settings, but I might be mistaken about that. -- Jeffrey McGrew Application Specialist BSD AEC Technologies, a division of ID8 Media Inc. (415) 593-6000 x 129 (415) 593-3333 Fax (415) 505-4689 Cell www.aectech.com www.id8media.com
*Aaron Rumple
Message 3 of 5 (1,158 Views)
06-09-2004 06:10 AM in reply to: TDKD
Viewports - ick. Crop Regions Rule. ;-) Unfortunately, crop regions are not saved as part of a View Template. View Templates only store information not specific to model geometry. A crop region needs to know what and where to crop. However you can turn on crop regions for multiple views at the same time once the views are on the sheet. Just select all the views on the sheet and open the Properties dialog. Toggle the Crop Region option so it is a black check and you are done. Each crop region can then be individually sized to meet the needs of each particular view. "Jeffrey McGrew" wrote in message news:40c674d6$1_2@newsprd01... > TDKD wrote: > > > I'm trying to add four views on a A3 sheet, one of the views had to be resized a little but its vewport remain same. Is it possible to resize vewports as well? I know I use to be able to create and add many viewports in ADT, can I add more than one in a single command in Revit? > > Yes. When you place a view on a sheet, Revit will assume a default > 'viewport' (to use ACAD/ADT terms) border to that view. If you instead > open/activate that view, go to view properties and select for it to > have a view crop region, then you'll have a user-created border around > that view that you can drag around (kinda like an xclip). Then you can > select for said border to not be visible in the same view properties, > and it won't show up, but continue to properly crop the view. > > To apply this change to multiple views, create a view template with > the desired settings, and then apply that to the views you want to > follow those settings. I think you can do this to more than one view > at a time to 'batch process' them all to the same settings, but I > might be mistaken about that. > > -- > Jeffrey McGrew > Application Specialist BSD > AEC Technologies, a division of ID8 Media Inc. > (415) 593-6000 x 129 > (415) 593-3333 Fax > (415) 505-4689 Cell > www.aectech.com > www.id8media.com
*Jeffrey McGrew
Message 4 of 5 (1,158 Views)
06-09-2004 09:27 AM in reply to: TDKD
Aaron Rumple wrote: > Unfortunately, crop regions are not saved as part of a View Template. View > Templates only store information not specific to model geometry. A crop > region needs to know what and where to crop. Thought that might be the case, just couldn't remember off the top of my head if it was. > However you can turn on crop regions for multiple views at the same time > once the views are on the sheet. Just select all the views on the sheet and > open the Properties dialog. Toggle the Crop Region option so it is a black > check and you are done. Each crop region can then be individually sized to > meet the needs of each particular view. You can also change the scale of all views this way too. Or, if you simply go to the sheet, and then go to the view properties of that sheet, if all views on that sheet are the same scale you'll be able to change them all at the same time here. -- Jeffrey McGrew Application Specialist BSD AEC Technologies, a division of ID8 Media Inc. (415) 593-6000 x 129 (415) 593-3333 Fax (415) 505-4689 Cell www.aectech.com www.id8media.com
Member
Message 5 of 5 (1,158 Views)
06-09-2004 04:38 PM in reply to: TDKD
Thank you guys, that solved it!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
