I am putting an internal screen family together.
As the wall wraps do not work on the soffit (only on reveals), I have used a sweep to match the wall plaster thickness to provide a finish.
Is it possible to report the host wall finish material and have it assigned to this sweep automatically ? I have tried to add a finish layer to the host wall in the family - but have not been able to find a way of extracting the material value for this layer.
For the moment I have left it as an Instance property for manual correction - but automated would be great.
Many thanks,
Martin
Reveals where wrapping works automatically:
I am not sure that my method will suit you ( I use families) ,but here it is:
Constantin Stroescu
Thanks Constantin,
I have the family working with the soffit insert as part of the internal screen family, and with the material assignment as an instance - I was wondering if it was possible to report the host wall's finish and use that assignment automatically. After spending an hour or so on it, I don't think it is possible at all - and it looks as though I will have to rely on the manual assignment.
It will generally be a plaster finish - although the paint / finish colour will vary.
Martin
in addition to my post I think that could be possible that the family described in there can be used as nested family in a Window Family with a Visibility Parameter to control if it is shown or not in Project. In a draft test seems that it could work....
Constantin Stroescu
