Winstong,
What is being shown is not a "rendering". It's using the new Visual Style
in Revit 2011 called "Realistic". In order to get this look, you set the
view to realistic, and then you change the Shadow settings in the View
Control Bar at the bottom of the screen. In the Sun and Shadow settings,
move the Cast Shadows slider all the way to Lighter, and set the Sun
Intensity to Brighter. This will make a display that has no "cast" shadows,
and the surfaces of the building will have very little shading on them.
Once again, this is not a rendering, but a visual style. Rendering in Revit
is a process that requires a light source. The rendering engine, mental
ray, is a lighting simulation engine. It literally bounces simulated
particles of light around a scene to produce a realistically lit image.
There will always be shadows in a rendered image.
"winstong" wrote in message news:6384329@discussion.autodesk.com...
this is great
i want the same effect
can u please guide me on how to do this.
Regards
winstong
