Hello, Im haiving problems witn my rendering, yesturday everithing was working fine but today everytimie i set rendering quality higher than draft, Revit either fails to render (rendering area goes black) or the pc crashes and i get bluescreen.
probably not a revit issue
thats a hardware problem most likely
your probably overheating the computer
DarrenP
I dont think so, as i said everything was warking fine. It goes to 10% of render in less than 10 seconds then it thinks a bit and it goes to 100% full complete render which is black...
My pc is intel i7 3.5ghz, 8gb ram and gefoce gtx680. I checked out the temperatures during the process and its slightly above 60.
I got message from revit: Unknown error occured...
Hi
I experienced such a thing time ago. But after restarting my computer twice, everything turned back fine.
Verify your graphics card, maybe it is not good enough for such mission!!!
have you looked up the blue screen error
that will tell what the problem is
its not going to be revit
DarrenP
go by this guide: http://www.pcworld.com/article/2023665/anatomy-of-a-pc-crash-7-scenarios-and-how-to-avoid-them.html
DarrenP
It is not happening in other projects, only in this one, blue screens are not showing up anymore, it just doesnt render.
