Rendering library disabled
1 REPLY 1
preethi17
211 Views, 1 Reply
I've installed Revit Architecture 2014. The materials folder is present in the autodesk shared folder. So there's no doubt that it has been installed. Yet, when I open, a pop up says "Rendering library is currently disabled." What do I do to get the rendering options?
Tags (1)
1 REPLY 1
ennujozlagam
in reply to: preethi17
hi, try this..
to resolve this issue, install the Autodesk Materials library, as follows:
  1. Start the Revit installation program and proceed to the Install > Configure Installation page.
  2. Under Shared Components, select the check box for the Autodesk Material Library.
  3. Click Install.
After the installation finishes, restart the Revit software. The rendering library error should no longer display.
shalom....
Rail Community
