Rendering in the cloud
3 REPLIES 3
TrevorC
468 Views, 3 Replies
Anyone having problems rendering in the cloud and some of the materials rendering really big. Let me know if there is a fix that I don't know about.
3 REPLIES 3
loboarch
in reply to: TrevorC
I have heard some reports of this issue.  It may be a units thing.  The cloud rendering engine may be reading inches as feet.  You can try changing the uints/resizing the material by a factor of 12 to see if that solves the problem.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
in reply to: loboarch
Hello, I am having the same problem, my renderings with the cloud show my walls with 4 big brick courses, while my "realistic" within Revit LT view shows the bricks the correct size.  Were you able to fix this?
cary.fulbright
Make sure you have the latest Revit Update Release, 2013 UR3 or 2014 UR2, which should address this issues.
