Anyone having problems rendering in the cloud and some of the materials rendering really big. Let me know if there is a fix that I don't know about.
Solved by loboarch. Go to Solution.
I have heard some reports of this issue. It may be a units thing. The cloud rendering engine may be reading inches as feet. You can try changing the uints/resizing the material by a factor of 12 to see if that solves the problem.
Hello, I am having the same problem, my renderings with the cloud show my walls with 4 big brick courses, while my "realistic" within Revit LT view shows the bricks the correct size. Were you able to fix this?
Make sure you have the latest Revit Update Release, 2013 UR3 or 2014 UR2, which should address this issues.
