Revit Architecture
New Member
nsweber
Message 1 of 4 (3,771 Views)
Rendering a Walkthrough
3771 Views, 3 Replies
04-30-2010 11:02 PM
I am trying to render a walkthrough that I have set up in my project and I can not figure out how to get the rendering started.
Valued Mentor
vector2
Message 2 of 4 (3,771 Views)
Re: Rendering a Walkthrough
04-30-2010 11:17 PM in reply to: nsweber
3Ds Max does that.. if you tried to do it in revit
it would take several months of rendering for
just a few seconds of animation..
but don't go away- amazing new
visual capabilities in RAC 2011 happen everyday.. Edited by: Discussion_Admin on May 2, 2010 8:25 PM
*Scott D Davis \(Autodesk\)
Message 3 of 4 (3,771 Views)
05-01-2010 09:09 AM in reply to: nsweber
When you export a Walkthrough (File>Export>Images and Animation), the Visual
Style drop down list in the export dialog has an entry for Rendering.
Choose it there, and your walkthrough will render as it is exported either
to an AVI or to a series of JPGs you can post-edit in a video editing
program.
"nsweber" wrote in message news:6384145@discussion.autodesk.com...
cbcarch
Message 4 of 4 (3,771 Views)
05-04-2010 05:56 AM in reply to: nsweber
Scott explains the process well.
It's worth mentioning that with Revit 2011, there is no longer a 4 CPU core limit on processors when rendering, so if you have a dual quad core machine, you can now create rendered walkthroughs in Revit.
Interior scenes with lots of artificial lighting will still take a long time due to Mental Ray calculating the raytracing.
Exterior scenes should render failrly quickly--you just need a computer with multiple processors and fast clock speed.
That said, it is still better to animate and render in 3dsMax, for high-quality visualizations, with its better camera control,
lighting and material editing, etc.
We use both methods; just depends on the scope, budget, schedule and end result you need.
cheers
Cliff B. Collins
Registered Architect/BIM Specialist
Autodesk Revit Expert Elite
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
