Hi, I am wondering how to make the siding in my project render the color I changed it to. I have changed the siding in my project to a green, but everytime I render it only shows in the standard bage color. Any help will be much appreciated.
Solved by constantin.stroescu. Go to Solution.
It is not very clear for me what you want to obtain but , I suppose you made diference in Material Browser between Graphics (Shading , Surface Pattern) that is uded for non realistic Visual Styles and Appearance where you make settings for rendering...
If the object is a badge , in the way I understand it, then, maybe it's better to use a Decal (Insert >Decal ) instead of a material....
Constantin Stroescu
