Rendering Problem Revit 2013
2 REPLIES 2
1026 Views, 2 Replies
Has anyone found a solution to the render problem? I keep getting a dialogue box that says "Revit was unable to render the view due to an unknown error during render calculations. The rendering operation will be canceled." The only option is to click "close" and when i do so, it continues to render but only the sky and grass. My buildings are not present. Any suggestions?
2 REPLIES 2
FYI I am running Revit 2013 through Parallels on a MacBook Pro.
I have no ideal about your Revit rendering issue, but i would like to suggest you to try "Render in Cloud" command beside the "Redner" command before the issue resolved.
