Is there a way to rename the Identity Data Parameter- Assembly Code?
Solved by Alfredo_Medina. Go to Solution.
No. Some parameters are kind of hard coded into the families, and cannot be changed.
just make your own shared parameter and use that instead. My is called AssblyCode
you can.
follow instructions as per the link below (basically editing a .txt file (uniformatClassifications.txt file)
worked for me. i had concrete piles with the assembly description as steel pipes (for some reason)
i closed my revit sessionI, went into the aformentioned .txt file and changed it to concrete.
apologies if i'm talking out of my left ear and misinterpreted what you mean.
Pete
