Is there a way to rename the Identity Data Parameter- Assembly Code?
Solved by Alfredo_Medina. Go to Solution.
No. Some parameters are kind of hard coded into the families, and cannot be changed.
you can.
follow instructions as per the link below (basically editing a .txt file (uniformatClassifications.txt file)
worked for me. i had concrete piles with the assembly description as steel pipes (for some reason)
i closed my revit sessionI, went into the aformentioned .txt file and changed it to concrete.
apologies if i'm talking out of my left ear and misinterpreted what you mean.
Pete
