Removing tag leader,
I couldn’t know how to remove the leader of the tag from its family. How this might be done?
Thank you
Best
Jamal
The leader is an automatic and can't be turned off - in the options bar you can uncheck Leader and then it will not place a leader. Circled below...
many thanks for the answer.
but why there is way to edit its family and thus we can choose it to be off by default?
I don't have a better answer other then it is how the system works. You can create any type of tag you would like - but you will always have a leader option available.
LD
many thanks. however, it works.
best
Jamal
There's away to remove tag leader in bulk.
1. SELECT SINGLE FAMILY INSTANTE
2. RIGHT CLICK, SELECT ALL INSTANCES IN VIEW OR IN PROJECT
3. WHILE SELECTION IS HIGHLIGHTED TO GO TO ANNOTATE MENU AND CHOOSE TAG ALL
4. DIALOG BOX OPENS WITH DIFFERENT TAGS IN PROJECT
5. SELECT THE TAG YOU WANT TO USE AND IN THE LOWER LEFT HAND CORNER THERE IS A CHECKBOX THAT SAYS LEADER. LEAVE IT UNCHECKED AND ALL OF YOUR TAGS WILL COME IN WITHOUT A LEADER.
Hi, I think you may be after the same thing I am. Is there a system variable to have the leader option turned off permanently. It then becomes a toggle ON when required. (Which is pretty much never.) Thanks Trace
No unfortunately there is not. But then again, it is a once per session setting.
Louis
Please mention Revit version, especially when uploading Revit files.
When you select TAG ALL in Annotate bar the window will show and you clear Leader for your item
"Please Solve"
