Removing singular dimensions
2 REPLIES 2
Michael_McInnes
9768 Views, 2 Replies
How do you remove singular dimensions from within a string of linear dimensions?
At the moment I cannot delete individual dimensions and am required to delete all dimensions in that string and start again.
2 REPLIES 2
CoreyDaun
in reply to: Michael_McInnes
If you are using Revit 2013 or later, you can hover the mouse cursor over the desired section of the Dimension string (the line, not the text), press TAB to highlight only that segment, click to select it, and then delete. If you are using an earlier version of Revit, then this is not possible.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
karunakaran1991
in reply to: CoreyDaun
Nice I'm also searching answer for the same question and finally I got it.
Rail Community
