How do you remove singular dimensions from within a string of linear dimensions?
At the moment I cannot delete individual dimensions and am required to delete all dimensions in that string and start again.
Solved by CoreyDaun. Go to Solution.
If you are using Revit 2013 or later, you can hover the mouse cursor over the desired section of the Dimension string (the line, not the text), press TAB to highlight only that segment, click to select it, and then delete. If you are using an earlier version of Revit, then this is not possible.
Nice I'm also searching answer for the same question and finally I got it.
