Revit Architecture
Active Contributor
Message 1 of 2 (67 Views)
Reintegrating Parts
67 Views, 1 Replies
11-29-2012 02:15 PM
Once an object such as a floor slab is divided into parts (e.g. for concrete pours) how does one reintegrate the parts into the whole slab again if one wants to find properties such as cubic yards for the entire slab?
Message 2 of 2 (55 Views)
Re: Reintegrating Parts
11-30-2012 05:40 AM in reply to: pete
You can use the Tab key to highlight the overall floor slab, and under Properties it will show the Area.
Same for the Divided Parts Area--Tab and you can select the Divided section(s), highlight and see Area under Properties.
Set your View to "Show Both" .
You can set it to "Show Original" as well as I recall.
Quantity Takeoff Schedules are a bit tricky with Parts--but you should be able to Schedule Floor Areas and include Parts. Good luck!
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
