Revit Architecture
Member
DHZ-Phoenix
Message 1 of 2 (339 Views)
Reinstall problem
339 Views, 1 Replies
05-05-2012 06:16 AM
I have a serious problem with the installation of Revit Architecture 2013.
I had to abort the installation of Revit using the task manager and to that effect, every time i retry to install the programm the installation manager tells me it is already installed.
I've performed the steps to do a clean install (removing all associated files and cleaning registry files) but got no result. When I go in the installation folder under x64 to install Revit directly (without using the manager), I get the following message: "Error 1606.Could not access network location Program."
I've drfited through the forums and even contacted support (probably based in India) who sent me to more forums. But nothing I found helped.
I am considering formating my Hard Drive now but I thought I would ask here before I do that.
Is there any way to get it to install without going through the trouble of reformating ?
*Expert Elite*
LisaDrago
Message 2 of 2 (291 Views)
Re: Reinstall problem
05-15-2012 04:50 AM in reply to: DHZ-Phoenix
Are you on subscription? If so put a support ticket in to Autodesk - keep contacting them until they help.
also you can contact your reseller and have them put a ticket into Autodesk to assist you.
They should be able to assist with this - if not - get a new reseller that provides support!
I would also try here - http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
