I have a serious problem with the installation of Revit Architecture 2013.
I had to abort the installation of Revit using the task manager and to that effect, every time i retry to install the programm the installation manager tells me it is already installed.
I've performed the steps to do a clean install (removing all associated files and cleaning registry files) but got no result. When I go in the installation folder under x64 to install Revit directly (without using the manager), I get the following message: "Error 1606.Could not access network location Program."
I've drfited through the forums and even contacted support (probably based in India) who sent me to more forums. But nothing I found helped.
I am considering formating my Hard Drive now but I thought I would ask here before I do that.
Is there any way to get it to install without going through the trouble of reformating ?
Are you on subscription? If so put a support ticket in to Autodesk - keep contacting them until they help.
also you can contact your reseller and have them put a ticket into Autodesk to assist you.
They should be able to assist with this - if not - get a new reseller that provides support!
I would also try here - http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
LD
